Giriş
By following the steps in this guide one should be able to replace the fan of a Dell Inspiron 7568 in under six minutes. The only tool necessary for this project is a Phillips #1 screwdriver.
Neye ihtiyacın var
Remove the ten 7mm Phillips #1 screws on the bottom cover.
Remove the bottom cover.
Begin by unclipping the cable connecting the fan and the motherboard.
Gently separate the motherboard cable from the clamp at the bottom of the fan.
Remove the cable.
3 farklı kişi bu kılavuzu tamamladı.
