Ana içeriğe geç
Dell Inspiron 7568 Display Assembly Replacement Guide
Neye ihtiyacın var
  1. Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: adım 1, 2 resimden 1. Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: adım 1, 2 resimden 2.
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 7568 Display Assembly Replacement Guide: adım 2, 2 resimden 1. Dell Inspiron 7568 Display Assembly Replacement Guide: adım 2, 2 resimden 2.
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: adım 3, 2 resimden 1. Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: adım 3, 2 resimden 2.
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
    • Doing this will allow one to access the LCD-motherboard connector cables.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 7568 Display Assembly Replacement Guide: adım 4, 2 resimden 1. Dell Inspiron 7568 Display Assembly Replacement Guide: adım 4, 2 resimden 2.
    • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
    FixBot'a Sor
    Yorum Ekle
  5. Dell Inspiron 7568 Display Assembly Replacement Guide: adım 5, 3 resimden 1. Dell Inspiron 7568 Display Assembly Replacement Guide: adım 5, 3 resimden 2. Dell Inspiron 7568 Display Assembly Replacement Guide: adım 5, 3 resimden 3.
    • Disconnect the antenna cable (under the left hinge)
    • Disconnect the LCD and Touchscreen display cables under the right hinge.
    • These are a set of two cables. For better image see image two in step one of this guide.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Inspiron 7568 Display Assembly Replacement Guide: adım 6, 1 resimden 1.
    • Carefully separate the screen from the bottom half of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Yash Samant
406 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G2, Lacy Spring 2017 USF Tampa, Team S2-G2, Lacy Spring 2017 üyesi
USFT-LACY-S17S2G2
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 1,294
