Ana içeriğe geç
Dell Inspiron 7568 Keyboard Replacement Guide
Neye ihtiyacın var
  1. Dell Inspiron 7568 Keyboard Replacement Guide, Battery: adım 1, 2 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide, Battery: adım 1, 2 resimden 2.
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 7568 Keyboard Replacement Guide: adım 2, 2 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide: adım 2, 2 resimden 2.
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 7568 Keyboard Replacement Guide, Display Assembly: adım 3, 2 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide, Display Assembly: adım 3, 2 resimden 2.
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
    • Doing this will allow one to access the LCD-motherboard connector cables.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 7568 Keyboard Replacement Guide: adım 4, 2 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide: adım 4, 2 resimden 2.
    • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
    FixBot'a Sor
    Yorum Ekle
  5. Dell Inspiron 7568 Keyboard Replacement Guide: adım 5, 3 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide: adım 5, 3 resimden 2. Dell Inspiron 7568 Keyboard Replacement Guide: adım 5, 3 resimden 3.
    • Disconnect the antenna cable (under the left hinge)
    • Disconnect the LCD and Touchscreen display cables under the right hinge.
    • These are a set of two cables. For better image see image two in step one of this guide.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Inspiron 7568 Keyboard Replacement Guide: adım 6, 1 resimden 1.
    • Carefully separate the screen from the bottom half of the device.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Inspiron 7568 Keyboard Replacement Guide, Cooling Fan: adım 7, 2 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide, Cooling Fan: adım 7, 2 resimden 2.
    • Begin by unclipping the cable connecting the fan and the motherboard.
    • Gently separate the motherboard cable from the clamp at the bottom of the fan.
    • Remove the cable.
    FixBot'a Sor
    Yorum Ekle
  8. Dell Inspiron 7568 Keyboard Replacement Guide: adım 8, 2 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide: adım 8, 2 resimden 2.
    • Remove the two 3mm Phillips #1 screws that hold the fan into place.
    • Remove the fan.
    FixBot'a Sor
    Yorum Ekle
  9. Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: adım 9, 3 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: adım 9, 3 resimden 2. Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: adım 9, 3 resimden 3.
    • Once the battery, screen, cooling fan, trackpad are out, the device would resemble the one in the first picture of this step.
    • Unscrew the three screws connecting the copper pipe to the motherboard.
    • Remove the copper pipe.
    FixBot'a Sor
    Yorum Ekle
  10. Dell Inspiron 7568 Keyboard Replacement Guide: adım 10, 3 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide: adım 10, 3 resimden 2. Dell Inspiron 7568 Keyboard Replacement Guide: adım 10, 3 resimden 3.
    • Unscrew the three 2mm wafer screws holding the motherboard.
    • Unplug the DC cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Dell Inspiron 7568 Keyboard Replacement Guide: adım 11, 2 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide: adım 11, 2 resimden 2.
    • Unplug the connecting strip
    FixBot'a Sor
    Yorum Ekle
  12. Dell Inspiron 7568 Keyboard Replacement Guide: adım 12, 3 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide: adım 12, 3 resimden 2. Dell Inspiron 7568 Keyboard Replacement Guide: adım 12, 3 resimden 3.
    • Unplug the hard-drive cable
    • Remove the motherboard
    FixBot'a Sor
    Yorum Ekle
  13. Dell Inspiron 7568 Keyboard Replacement Guide: adım 13, 2 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide: adım 13, 2 resimden 2.
    • Unscrew the three 3mm screws holding the hard drive (using a ph1 screwdriver bit)
    • Remove the hard drive
    FixBot'a Sor
    Yorum Ekle
  14. Dell Inspiron 7568 Keyboard Replacement Guide: adım 14, 2 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide: adım 14, 2 resimden 2.
    • Unscrew the two 3mm screws holding the daughter board (using the ph1 screwdriver bit).
    • Set the daughterboard aside. NOTE: the daughter board doesn't have to be removed
    FixBot'a Sor
    Yorum Ekle
  15. Dell Inspiron 7568 Keyboard Replacement Guide: adım 15, 2 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide: adım 15, 2 resimden 2.
    • Unscrew & remove the twenty-eight 2mm bracket screws holding the keyboard bracket (using a PH000 screwdriver bit)
    • Remove the keyboard bracket
    FixBot'a Sor
    Yorum Ekle
  16. Dell Inspiron 7568 Keyboard Replacement Guide: adım 16, 1 resimden 1.
    • Unscrew & remove the sixteen 2mm screws holding the keyboard (using a PH000 screwdriver bit)
    FixBot'a Sor
    Yorum Ekle
  17. Dell Inspiron 7568 Keyboard Replacement Guide: adım 17, 3 resimden 1. Dell Inspiron 7568 Keyboard Replacement Guide: adım 17, 3 resimden 2. Dell Inspiron 7568 Keyboard Replacement Guide: adım 17, 3 resimden 3.
    • Unplug the keyboard ("KB") and backlight ("BL") cable
    • Remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Luis Velez
452 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G2, Lacy Spring 2017 USF Tampa, Team S2-G2, Lacy Spring 2017 üyesi
USFT-LACY-S17S2G2
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 5
Son 30 gün: 46
Her zaman: 1,422
