Ana içeriğe geç
Dell Inspiron 7568 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 7568 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 7568 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Motherboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 7568 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Motherboard Replacement, RAM: adım 3, 1 resimden 1.
    • Release the RAM by unhinging the connecting bars outward.
  4. Dell Inspiron 7568 Motherboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 7568 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the RAM.
  5. Dell Inspiron 7568 Motherboard Replacement, Cooling Fan: adım 5, 2 resimden 1. Dell Inspiron 7568 Motherboard Replacement, Cooling Fan: adım 5, 2 resimden 2.
    • Begin by unclipping the cable connecting the fan and the motherboard.
    • Gently separate the motherboard cable from the clamp at the bottom of the fan.
    • Remove the cable.
  6. Dell Inspiron 7568 Motherboard Replacement: adım 6, 2 resimden 1. Dell Inspiron 7568 Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the two 3mm Phillips #1 screws that hold the fan into place.
    • Remove the fan.
  7. Dell Inspiron 7568 Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Dell Inspiron 7568 Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove six 3mm Phillips #1 screws to fully remove the motherboard.
    • Disconnect the various connection points from the motherboard to the laptop.
    • Remove the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elijah Basile
358 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Stella Fall 2019 IUPUI, Team S1-G4, Stella Fall 2019 üyesi
IUPUI-STELLA-F19S1G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 292
