Ana içeriğe geç
Dell Inspiron 7568 Trackpad Replacement Guide
Neye ihtiyacın var
  1. Dell Inspiron 7568 Trackpad Replacement Guide, Battery: adım 1, 2 resimden 1. Dell Inspiron 7568 Trackpad Replacement Guide, Battery: adım 1, 2 resimden 2.
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Trackpad Replacement Guide: adım 2, 2 resimden 1. Dell Inspiron 7568 Trackpad Replacement Guide: adım 2, 2 resimden 2.
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Trackpad Replacement Guide, Track Pad: adım 3, 2 resimden 1. Dell Inspiron 7568 Trackpad Replacement Guide, Track Pad: adım 3, 2 resimden 2.
    • Unplug the speaker cable and remove the speakers
  4. Dell Inspiron 7568 Trackpad Replacement Guide: adım 4, 2 resimden 1. Dell Inspiron 7568 Trackpad Replacement Guide: adım 4, 2 resimden 2.
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) holding the touchpad bracket
    • Remove the touchpad bracket
  5. Dell Inspiron 7568 Trackpad Replacement Guide: adım 5, 3 resimden 1. Dell Inspiron 7568 Trackpad Replacement Guide: adım 5, 3 resimden 2. Dell Inspiron 7568 Trackpad Replacement Guide: adım 5, 3 resimden 3.
    • Use a nylon spudger to lift the ZIF connector tab. Gently pull the touchpad ribbon cable free.
    • Use a nylon spudger to lift the ZIF connector tab. Gently pull the keyboard daughter board ribbon cable free.
  6. Dell Inspiron 7568 Trackpad Replacement Guide: adım 6, 3 resimden 1. Dell Inspiron 7568 Trackpad Replacement Guide: adım 6, 3 resimden 2. Dell Inspiron 7568 Trackpad Replacement Guide: adım 6, 3 resimden 3.
    • Remove the touchpad foil using a spudger or other ESD safe blunt-tip tool.
    • Unscrew & remove the three 2mm wafer screws holding the touchpad.
    • Remove the touchpad.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Yash Samant
394 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G2, Lacy Spring 2017 USF Tampa, Team S2-G2, Lacy Spring 2017 üyesi
USFT-LACY-S17S2G2
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 322
