Ana içeriğe geç
Dell Inspiron 7568 Wifi Card Replacement
Neye ihtiyacın var
  1. Dell Inspiron 7568 Wifi Card Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 7568 Wifi Card Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Wifi Card Replacement: adım 2, 2 resimden 1. Dell Inspiron 7568 Wifi Card Replacement: adım 2, 2 resimden 2.
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Wifi Card Replacement, Hard-Drive: adım 3, 1 resimden 1.
    • Remove the three 3mm Phillips #1 screws connecting the hard drive to the laptop.
  4. Dell Inspiron 7568 Wifi Card Replacement: adım 4, 2 resimden 1. Dell Inspiron 7568 Wifi Card Replacement: adım 4, 2 resimden 2.
    • Disconnect the highlighted SATA cable from the hard drive.
  5. Dell Inspiron 7568 Wifi Card Replacement: adım 5, 1 resimden 1.
    • Remove the four 3mm Phillips #1 screws of the hard drive. Both sides look identical.
  6. Dell Inspiron 7568 Wifi Card Replacement: adım 6, 1 resimden 1.
    • Remove the hard drive (right) from its frame (left).
  7. Dell Inspiron 7568 Wifi Card Replacement, Wifi Card: adım 7, 2 resimden 1. Dell Inspiron 7568 Wifi Card Replacement, Wifi Card: adım 7, 2 resimden 2.
    • Remove the wide-brimmed 3mm Phillips #1 screw connecting the Wifi Card.
    • Remove the Wifi Card.
Sonuç
Elijah Basile
358 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Stella Fall 2019 IUPUI, Team S1-G4, Stella Fall 2019 üyesi
IUPUI-STELLA-F19S1G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 158
