Ana içeriğe geç
Dell Inspiron 7573 2-in-1 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Battery Replacement: adım 2, 3 resimden 1. Dell Inspiron 7573 2-in-1 Battery Replacement: adım 2, 3 resimden 2. Dell Inspiron 7573 2-in-1 Battery Replacement: adım 2, 3 resimden 3.
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Battery Replacement: adım 4, 3 resimden 1. Dell Inspiron 7573 2-in-1 Battery Replacement: adım 4, 3 resimden 2. Dell Inspiron 7573 2-in-1 Battery Replacement: adım 4, 3 resimden 3.
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kylie Freese
405 İtibar
3 adet Kılavuz yazıldı
Ekip
Casper College, Team 1-2, Lareau Fall 2021 Casper College, Team 1-2, Lareau Fall 2021 üyesi
CASC-LAREAU-F21S1G2
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 2,264
