Ana içeriğe geç
Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement
Neye ihtiyacın var
  1. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 2, 3 resimden 1. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 2, 3 resimden 2. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 2, 3 resimden 3.
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 3, 1 resimden 1.
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 4, 3 resimden 1. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 4, 3 resimden 2. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 4, 3 resimden 3.
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
  5. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Memory Modules: adım 5, 2 resimden 1. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Memory Modules: adım 5, 2 resimden 2.
    • Peel back the mylar coverings on the RAM chips on the right side of the system board.
  6. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 6, 3 resimden 1. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 6, 3 resimden 2. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 6, 3 resimden 3.
    • Push outward on the two gray tabs on either side of the RAM module.
    • These tabs hold down the RAM modules, which should pop up when disengaged.
    • Gently pull the memory module out of its slot.
    • Be sure to only touch the edges of the RAM module, as the oil from your fingers can damage the components on the face.
  7. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 7, 1 resimden 1.
    • With the new memory module, line up the notch on the memory with the tab on the module slot.
    • Insert the memory module at an angle.
    • Push down on the module until the locking tabs on either side click into place.
    • If there is no click, reinsert the module.
  8. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: adım 8, 1 resimden 1.
    • Repeat steps 5-7 for the other memory module.
    • In this laptop, one set of tabs was gray plastic and the other was metallic.
    • When pushing down on the memory modules, make sure you hear a click.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brady Kennedy
109 İtibar
1 Kılavuz yazıldı
Ekip
Casper College, Team 1-2, Lareau Fall 2021 Casper College, Team 1-2, Lareau Fall 2021 üyesi
CASC-LAREAU-F21S1G2
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 436
