Giriş
This guide is designed to help you replace or upgrade the NVMe SSD in your Dell Inspirion 7586 2 in 1 laptop.
CPU: Intel Core i7-8565U 1.80 GHz
Chipset: Whiskey Lake
RAM: DDR4-16GB-2666MHz
SSD: SK hynix PCIe NVMe 512GB
GPU: NVIDIA GeForce MX150
OS: Windows 10 Pro
Before you begin this repair, turn off your laptop and unplug it from the charger.
Neye ihtiyacın var
Flip the laptop over so the bottom is facing up.
Use a Phillips #00 screwdriver to remove nine screws from the back case.
Insert an opening tool or spudger in the seam between the back case and the body of the laptop.
Work your way around the perimeter of the laptop and release the clips that secure the back case.
Remove the back case.
2 farklı kişi bu kılavuzu tamamladı.
