Ana içeriğe geç
Dell Inspiron 8600 Display Removal
Neye ihtiyacın var
  1. Dell Inspiron 8600 Display Removal, Battery: adım 1, 1 resimden 1.
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Display Removal, Hinge Cover: adım 2, 3 resimden 1. Dell Inspiron 8600 Display Removal, Hinge Cover: adım 2, 3 resimden 2. Dell Inspiron 8600 Display Removal, Hinge Cover: adım 2, 3 resimden 3.
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Display Removal: adım 3, 1 resimden 1.
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Display Removal, Display Module: adım 4, 2 resimden 1. Dell Inspiron 8600 Display Removal, Display Module: adım 4, 2 resimden 2.
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Display Removal: adım 5, 1 resimden 1.
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Display Removal: adım 6, 2 resimden 1. Dell Inspiron 8600 Display Removal: adım 6, 2 resimden 2.
    • Lift the display module directly upwards from the base of the computer.
  7. Dell Inspiron 8600 Display Removal: adım 7, 1 resimden 1.
    • Now remove the display module.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Victor
187 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G22
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 3,930
