Ana içeriğe geç
Dell Inspiron 8600 LCD Replacement
Neye ihtiyacın var
  1. Dell Inspiron 8600 LCD Replacement, Hinge Cover: adım 1, 3 resimden 1. Dell Inspiron 8600 LCD Replacement, Hinge Cover: adım 1, 3 resimden 2. Dell Inspiron 8600 LCD Replacement, Hinge Cover: adım 1, 3 resimden 3.
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  2. Dell Inspiron 8600 LCD Replacement: adım 2, 1 resimden 1.
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  3. Dell Inspiron 8600 LCD Replacement, Display Module: adım 3, 2 resimden 1. Dell Inspiron 8600 LCD Replacement, Display Module: adım 3, 2 resimden 2.
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  4. Dell Inspiron 8600 LCD Replacement: adım 4, 1 resimden 1.
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  5. Dell Inspiron 8600 LCD Replacement: adım 5, 2 resimden 1. Dell Inspiron 8600 LCD Replacement: adım 5, 2 resimden 2.
    • Lift the display module directly upwards from the base of the computer.
  6. Dell Inspiron 8600 LCD Replacement: adım 6, 1 resimden 1.
    • Now remove the display module.
  7. Dell Inspiron 8600 LCD Replacement, LCD: adım 7, 3 resimden 1. Dell Inspiron 8600 LCD Replacement, LCD: adım 7, 3 resimden 2. Dell Inspiron 8600 LCD Replacement, LCD: adım 7, 3 resimden 3.
    • First, remove the plastic tabs that are covering the interior screws.
    • After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
    • Note there are 8 tabs and 8 screws in total.
  8. Dell Inspiron 8600 LCD Replacement: adım 8, 1 resimden 1.
    • Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
  9. Dell Inspiron 8600 LCD Replacement: adım 9, 1 resimden 1.
    • Using a Philips #1 screwdriver remove the screws holding the LCD in place.
    • Note there are 8 screws in total for this step, 4 on each side of the unit.
  10. Dell Inspiron 8600 LCD Replacement: adım 10, 1 resimden 1.
    • Remove the broken LCD unit, and replace with new unit.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Perry
251 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G22
4 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
which controller board do i have to use for this model ?
bcdoor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 4,637
