Ana içeriğe geç
Dell Inspiron 8600 Power Button Replacement
Neye ihtiyacın var
  1. Dell Inspiron 8600 Power Button Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Power Button Replacement, Power Button: adım 2, 3 resimden 1. Dell Inspiron 8600 Power Button Replacement, Power Button: adım 2, 3 resimden 2. Dell Inspiron 8600 Power Button Replacement, Power Button: adım 2, 3 resimden 3.
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Power Button Replacement: adım 3, 1 resimden 1.
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brian Murphy
368 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G22
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 4,173
