Ana içeriğe geç
Dell Inspiron 8600 Proccessor (CPU) Replacement
Neye ihtiyacın var
  1. Dell Inspiron 8600 Proccessor (CPU) Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Proccessor (CPU) Replacement, Hinge Cover: adım 2, 3 resimden 1. Dell Inspiron 8600 Proccessor (CPU) Replacement, Hinge Cover: adım 2, 3 resimden 2. Dell Inspiron 8600 Proccessor (CPU) Replacement, Hinge Cover: adım 2, 3 resimden 3.
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Proccessor (CPU) Replacement: adım 3, 1 resimden 1.
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Proccessor (CPU) Replacement, Display Module: adım 4, 2 resimden 1. Dell Inspiron 8600 Proccessor (CPU) Replacement, Display Module: adım 4, 2 resimden 2.
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Proccessor (CPU) Replacement: adım 5, 1 resimden 1.
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Proccessor (CPU) Replacement: adım 6, 2 resimden 1. Dell Inspiron 8600 Proccessor (CPU) Replacement: adım 6, 2 resimden 2.
    • Lift the display module directly upwards from the base of the computer.
  7. Dell Inspiron 8600 Proccessor (CPU) Replacement: adım 7, 1 resimden 1.
    • Now remove the display module.
  8. Dell Inspiron 8600 Proccessor (CPU) Replacement, Proccessor (CPU): adım 8, 3 resimden 1. Dell Inspiron 8600 Proccessor (CPU) Replacement, Proccessor (CPU): adım 8, 3 resimden 2. Dell Inspiron 8600 Proccessor (CPU) Replacement, Proccessor (CPU): adım 8, 3 resimden 3.
    • Locate and remove the top two screws and all the screws on the underside holding the top case down.
    • Gently pop off the top plastic case from the unit.
  9. Dell Inspiron 8600 Proccessor (CPU) Replacement: adım 9, 3 resimden 1. Dell Inspiron 8600 Proccessor (CPU) Replacement: adım 9, 3 resimden 2. Dell Inspiron 8600 Proccessor (CPU) Replacement: adım 9, 3 resimden 3.
    • Remove the copper heat sink that is housing the CPU by removing the four securing screws.
    • Gently lift and remove the heat sink.
  10. Dell Inspiron 8600 Proccessor (CPU) Replacement: adım 10, 2 resimden 1. Dell Inspiron 8600 Proccessor (CPU) Replacement: adım 10, 2 resimden 2.
    • Gently loosen but do not remove the screw, and lift the CPU.
    • You will have to remove and replace the How to Apply Thermal Paste on the CPU base.
    • You may now replace the CPU.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
John Nesthus
186 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G22
4 Üyeler
16 adet Kılavuz yazıldı
2 Yorum
you can actually Simplify this a Lot by removing the fan on the bottom shown in Step 1 upper Right side then once you get to step 8 you only have to remove the screws for the processor heatsink and then bam your processor is able to be removed or replaced
DW
Duane Wasylyshen - Yanıt
The Dell Inspiron 8600 I have (not sure the year) I had to remove the keyboard to access the CPU.. Remove two screws holding the keyboard down and lift on the white tab. Remove the fan (two screws and the fan comes right out).. That give you more room to remove the heat exchanger. Other than that it was SUPER EASY !!! Thanks
nycny10025 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 7,112
