Ana içeriğe geç
Dell Inspiron 8600 Top Case Replacement
Neye ihtiyacın var
  1. Dell Inspiron 8600 Top Case Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Top Case Replacement, Power Button: adım 2, 3 resimden 1. Dell Inspiron 8600 Top Case Replacement, Power Button: adım 2, 3 resimden 2. Dell Inspiron 8600 Top Case Replacement, Power Button: adım 2, 3 resimden 3.
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Top Case Replacement: adım 3, 1 resimden 1.
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
  4. Dell Inspiron 8600 Top Case Replacement, Display Module: adım 4, 2 resimden 1. Dell Inspiron 8600 Top Case Replacement, Display Module: adım 4, 2 resimden 2.
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Top Case Replacement: adım 5, 1 resimden 1.
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Top Case Replacement: adım 6, 2 resimden 1. Dell Inspiron 8600 Top Case Replacement: adım 6, 2 resimden 2.
    • Lift the display module directly upwards from the base of the computer.
  7. Dell Inspiron 8600 Top Case Replacement: adım 7, 1 resimden 1.
    • Now remove the display module.
  8. Dell Inspiron 8600 Top Case Replacement, Top Case: adım 8, 3 resimden 1. Dell Inspiron 8600 Top Case Replacement, Top Case: adım 8, 3 resimden 2. Dell Inspiron 8600 Top Case Replacement, Top Case: adım 8, 3 resimden 3.
    • First, remove all tabs using a flat head/ finger.
    • Next, remove all screws using a #1 Philips screwdriver.
    • Pull apart top case from the lower case. It will be quite difficult to separate.
  9. Dell Inspiron 8600 Top Case Replacement: adım 9, 3 resimden 1. Dell Inspiron 8600 Top Case Replacement: adım 9, 3 resimden 2. Dell Inspiron 8600 Top Case Replacement: adım 9, 3 resimden 3.
    • Remove all screws on the top of the lcd
    • There all several screw on each side of the LCD. Remove all.
  10. Dell Inspiron 8600 Top Case Replacement: adım 10, 1 resimden 1.
    • LCD should remove smoothly.
    • The top case will be what remains.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Perry
251 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G22
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 2,223
