Ana içeriğe geç
Dell Inspiron 8600 Video Card Replacement
Neye ihtiyacın var
    1. Dell Inspiron 8600 Video Card Replacement, Battery: adım 1, 1 resimden 1.
      • Remove the battery from the bottom left of the laptop as shown.
      • Remove the battery before operating on the computer to avoid electrocution.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 8600 Video Card Replacement, Hinge Cover: adım 2, 3 resimden 1. Dell Inspiron 8600 Video Card Replacement, Hinge Cover: adım 2, 3 resimden 2. Dell Inspiron 8600 Video Card Replacement, Hinge Cover: adım 2, 3 resimden 3.
      • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
      • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
      • Be careful of the wire attached to the underside of the hinge cover.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 8600 Video Card Replacement: adım 3, 1 resimden 1.
      • Pull the small black tab on the right hand side of the laptop.
      • You have now removed the hinge cover.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 8600 Video Card Replacement, Keyboard: adım 4, 3 resimden 1. Dell Inspiron 8600 Video Card Replacement, Keyboard: adım 4, 3 resimden 2. Dell Inspiron 8600 Video Card Replacement, Keyboard: adım 4, 3 resimden 3.
      • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
      • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
      • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
      • The keyboard should be easily removable at this point.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 8600 Video Card Replacement, Video Card: adım 5, 3 resimden 1. Dell Inspiron 8600 Video Card Replacement, Video Card: adım 5, 3 resimden 2. Dell Inspiron 8600 Video Card Replacement, Video Card: adım 5, 3 resimden 3.
      • After removing the keyboard, locate and remove the labeled screws.
      • Gently lift the Video Card unit for replacing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brian Murphy
368 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G22
4 Üyeler
31 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 39
Her zaman: 7,595
