Ana içeriğe geç
Dell Inspiron 910 Screen Replacement
Neye ihtiyacın var
  1. Dell Inspiron 910 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Screen Replacement, Screen: adım 2, 1 resimden 1.
    • Using a plastic opening tool, pry the front silver bezel away from the colored plastic shell.
  3. Dell Inspiron 910 Screen Replacement: adım 3, 1 resimden 1.
    • Unscrew the two screws using a Phillips #00 screwdriver from the metal casing that retains the screen.
  4. Dell Inspiron 910 Screen Replacement: adım 4, 1 resimden 1.
    • Pull down the laptop's back, keeping the screen upright, held in place by two metal strips going along its sides.
    • Unscrew the 4 screws from the two strips.
    • While unscrewing the second side, make sure to hold the screen so that it doesn't fall when the screws are removed.
  5. Dell Inspiron 910 Screen Replacement: adım 5, 1 resimden 1.
    • Gently lay the screen down, being careful not to damage the ribbon connector.
  6. Dell Inspiron 910 Screen Replacement: adım 6, 1 resimden 1.
    • Disconnect the cord connecting the screen to the rest of the laptop. The cable will be attached to the screen using tape, so it can be safely removed. The actual cord connection is at the circuit board.
  7. Dell Inspiron 910 Screen Replacement: adım 7, 1 resimden 1.
    • Pull the screen out. Congratulations! You have removed the screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kyle Beekman
144 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Forte Spring 2012 Cal Poly, Team 14-10, Forte Spring 2012 üyesi
CPSU-FORTE-S12S14G10
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 2,440
