Giriş
This guide will teach you how to remove the buttons below the track pad from the laptop device.
Aletler
Parçalar
Hiçbir parçaya gerek yok.
Locate the release tabs located on either side of the battery, on the bottom of the laptop
Push the release tabs toward the center of the device.
Remove the battery.
Remove the two countersunk keyboard screws using the Phillips #00 screwdriver
Remove the seven Phillips #00 screws that hold the metal component to the frame
Detach the two ribbon cables on either side of the silver panel
Gently lift the silver panel from the laptop using the plastic opening tool
Set the laptop aside
Bir başkası bu kılavuzu tamamladı.
