Ana içeriğe geç
Dell Inspiron 9100 Keyboard Replacement
Neye ihtiyacın var
    1. Dell Inspiron 9100 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 9100 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 9100 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
      • Unplug the laptop from the power adapter and turn the power off.
      • Failure to unplug laptop before proceeding could result in risk of electric shock!
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 9100 Keyboard Replacement: adım 2, 3 resimden 1. Dell Inspiron 9100 Keyboard Replacement: adım 2, 3 resimden 2. Dell Inspiron 9100 Keyboard Replacement: adım 2, 3 resimden 3.
      • Slide the battery-lock tab and hold.
      • Flip the battery away from the chassis to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 9100 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
      • Turn the laptop around.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 9100 Keyboard Replacement: adım 4, 3 resimden 1. Dell Inspiron 9100 Keyboard Replacement: adım 4, 3 resimden 2. Dell Inspiron 9100 Keyboard Replacement: adım 4, 3 resimden 3.
      • Use your fingers to gently pull up on the hinge covers. They will release with an audible snap.
      • Fold the screen back to 180 degrees.
      • Using your index fingers, pull up the hinge cover.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 9100 Keyboard Replacement: adım 5, 3 resimden 1. Dell Inspiron 9100 Keyboard Replacement: adım 5, 3 resimden 2. Dell Inspiron 9100 Keyboard Replacement: adım 5, 3 resimden 3.
      • After the hinges pop, pull the hinge cover gently.
      • Pull the clear tab on the right side of the laptop up. This tab will disconnect the hinge cover from the laptop.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 9100 Keyboard Replacement: adım 6, 1 resimden 1.
      • Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
      FixBot'a Sor
      Yorum Ekle
    5. Dell Inspiron 9100 Keyboard Replacement: adım 7, 3 resimden 1. Dell Inspiron 9100 Keyboard Replacement: adım 7, 3 resimden 2. Dell Inspiron 9100 Keyboard Replacement: adım 7, 3 resimden 3.
      • Tilt the keyboard away from the screen.
      • Pull up on the white tab underneath the keyboard to release the keyboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ana
111 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-2, Forte Winter 2011 Cal Poly, Team 13-2, Forte Winter 2011 üyesi
CPSU-FORTE-W11S13G2
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 36
Her zaman: 4,384
