Ana içeriğe geç
Dell Inspiron 9100 Memory Replacement
Neye ihtiyacın var
  1. Dell Inspiron 9100 Memory Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 9100 Memory Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 9100 Memory Replacement, Battery: adım 1, 3 resimden 3.
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Memory Replacement: adım 2, 3 resimden 1. Dell Inspiron 9100 Memory Replacement: adım 2, 3 resimden 2. Dell Inspiron 9100 Memory Replacement: adım 2, 3 resimden 3.
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Memory Replacement, Memory: adım 3, 2 resimden 1. Dell Inspiron 9100 Memory Replacement, Memory: adım 3, 2 resimden 2.
    • Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
    • This screw will remain in the panel.
    • Pull the cover away from the laptop using your finger.
  4. Dell Inspiron 9100 Memory Replacement: adım 4, 3 resimden 1. Dell Inspiron 9100 Memory Replacement: adım 4, 3 resimden 2. Dell Inspiron 9100 Memory Replacement: adım 4, 3 resimden 3.
    • Use your fingertips to carefully spread apart the plastic white tabs.
    • Flip the RAM up at a 45 degree angle and remove it.
    • Hold the RAM by the edges only.
    • Ground yourself while dealing with RAM. Static shock can damage the memory. Store the RAM in an anti-static bag while it is not in use.
  5. Dell Inspiron 9100 Memory Replacement: adım 5, 1 resimden 1.
    • Repeat step four with the second RAM.
Sonuç
charlierefvem
854 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-2, Forte Winter 2011 Cal Poly, Team 13-2, Forte Winter 2011 üyesi
CPSU-FORTE-W11S13G2
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 3,526
