Ana içeriğe geç
Dell Inspiron 9300 Keyboard Replacement
Neye ihtiyacın var
    1. Dell Inspiron 9300 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
      • Use the spudger to remove the top cover plate to expose the screws for the keyboard.
      • Be sure not to break the clips holding it in. Once the side has been lifted, gently lift the plate with your hand to remove it completely.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 9300 Keyboard Replacement: adım 2, 1 resimden 1.
      • Remove the two 5mm Phillips screws holding the keyboard in place.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 9300 Keyboard Replacement: adım 3, 1 resimden 1.
      • Pull the keyboard away from the laptop.
      • Be careful when pulling the keyboard not to damage the connecting ribbon underneath.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 9300 Keyboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 9300 Keyboard Replacement: adım 4, 2 resimden 2.
      • Gently pull up on the blue tab to disconnect the keyboard.
      • Pull the keyboard up and away to safely remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ady Alhamra
149 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Eyestone Fall 2016 USF Tampa, Team 16-6, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G6
5 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 812
