Ana içeriğe geç
Dell Inspiron 9300 Trackpad Replacement
Neye ihtiyacın var
    1. Dell Inspiron 9300 Trackpad Replacement, Trackpad: adım 1, 1 resimden 1.
      • Remove the battery in to order avoid damaging internal components.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 9300 Trackpad Replacement: adım 2, 1 resimden 1.
      • Remove the twelve 6mm Phillips screws from the bottom of the case.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 9300 Trackpad Replacement: adım 3, 1 resimden 1.
      • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
      • There is a notch on the right-hand side of the bezel for easiest removal.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 9300 Trackpad Replacement: adım 4, 3 resimden 1. Dell Inspiron 9300 Trackpad Replacement: adım 4, 3 resimden 2. Dell Inspiron 9300 Trackpad Replacement: adım 4, 3 resimden 3.
      • Remove the two 5mm Phillips screws retaining the keyboard.
      • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
      • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward, away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Dell Inspiron 9300 Trackpad Replacement: adım 5, 2 resimden 1. Dell Inspiron 9300 Trackpad Replacement: adım 5, 2 resimden 2.
      • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
      • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
      • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
      FixBot'a Sor
      Yorum Ekle
    6. Dell Inspiron 9300 Trackpad Replacement: adım 6, 2 resimden 1. Dell Inspiron 9300 Trackpad Replacement: adım 6, 2 resimden 2.
      • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
      • Gently pry the CMOS battery out of its retaining clip using a spudger.
      FixBot'a Sor
      Yorum Ekle
    7. Dell Inspiron 9300 Trackpad Replacement: adım 7, 2 resimden 1. Dell Inspiron 9300 Trackpad Replacement: adım 7, 2 resimden 2.
      • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
      • Remove the trackpad ribbon cable from the motherboard using a spudger.
      FixBot'a Sor
      Yorum Ekle
    8. Dell Inspiron 9300 Trackpad Replacement: adım 8, 1 resimden 1.
      • Pull up and away on the upper case to remove.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Steven Faulkner
214 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Eyestone Fall 2016 USF Tampa, Team 16-6, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G6
5 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 504
