Ana içeriğe geç
Dell Inspiron 9300 Trackpad Replacement
Neye ihtiyacın var
  1. Dell Inspiron 9300 Trackpad Replacement, Trackpad: adım 1, 1 resimden 1.
    • Remove the battery in to order avoid damaging internal components.
  2. Dell Inspiron 9300 Trackpad Replacement: adım 2, 1 resimden 1.
    • Remove the twelve 6mm Phillips case screws from the bottom of the case.
  3. Dell Inspiron 9300 Trackpad Replacement: adım 3, 1 resimden 1.
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
  4. Dell Inspiron 9300 Trackpad Replacement: adım 4, 3 resimden 1. Dell Inspiron 9300 Trackpad Replacement: adım 4, 3 resimden 2. Dell Inspiron 9300 Trackpad Replacement: adım 4, 3 resimden 3.
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard
  5. Dell Inspiron 9300 Trackpad Replacement: adım 5, 2 resimden 1. Dell Inspiron 9300 Trackpad Replacement: adım 5, 2 resimden 2.
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  6. Dell Inspiron 9300 Trackpad Replacement: adım 6, 2 resimden 1. Dell Inspiron 9300 Trackpad Replacement: adım 6, 2 resimden 2.
    • Remove the seven 6mm Phillips scres holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger
  7. Dell Inspiron 9300 Trackpad Replacement: adım 7, 2 resimden 1. Dell Inspiron 9300 Trackpad Replacement: adım 7, 2 resimden 2.
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger
    • Remove the trackpad ribbon cable from the motherboard using a spudger
  8. Dell Inspiron 9300 Trackpad Replacement: adım 8, 1 resimden 1.
    • Pull up and away on the uppercase to remove.
Sonuç
Steven Faulkner
214 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Eyestone Fall 2016 USF Tampa, Team 16-6, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G6
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 172
