Ana içeriğe geç
Dell Inspiron 9300 Video Card Replacement
Neye ihtiyacın var
    1. Dell Inspiron 9300 Video Card Replacement, Prerequisite Only: adım 1, 2 resimden 1. Dell Inspiron 9300 Video Card Replacement, Prerequisite Only: adım 1, 2 resimden 2.
      • Remove the battery prior to working on any internal components.
      • Remove the twelve 6mm Phillips screws from the bottom of the case.
      • Remove the battery before working on internal components to ensure a safe working environment.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 9300 Video Card Replacement: adım 2, 1 resimden 1.
      • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
      • Start on the right hand side, where there is a notch in the bezel for easiest removal.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 9300 Video Card Replacement: adım 3, 3 resimden 1. Dell Inspiron 9300 Video Card Replacement: adım 3, 3 resimden 2. Dell Inspiron 9300 Video Card Replacement: adım 3, 3 resimden 3.
      • Remove the two 5mm Phillips screws retaining the keyboard.
      • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
      • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 9300 Video Card Replacement: adım 4, 2 resimden 1. Dell Inspiron 9300 Video Card Replacement: adım 4, 2 resimden 2.
      • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
      • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
      • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
      FixBot'a Sor
      Yorum Ekle
    5. Dell Inspiron 9300 Video Card Replacement: adım 5, 2 resimden 1. Dell Inspiron 9300 Video Card Replacement: adım 5, 2 resimden 2.
      • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
      • Gently pry the CMOS battery out of its retaining clip using a spudger.
      FixBot'a Sor
      Yorum Ekle
    6. Dell Inspiron 9300 Video Card Replacement: adım 6, 2 resimden 1. Dell Inspiron 9300 Video Card Replacement: adım 6, 2 resimden 2.
      • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
      • Remove the trackpad ribbon cable from the motherboard using a spudger.
      FixBot'a Sor
      Yorum Ekle
    7. Dell Inspiron 9300 Video Card Replacement: adım 7, 2 resimden 1. Dell Inspiron 9300 Video Card Replacement: adım 7, 2 resimden 2.
      • Pull up and away on the track pad to expose the internal components below.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 9300 Video Card Replacement, Video Card: adım 8, 1 resimden 1.
      • Loosen the four 5mm Phillips screws holding the video card and heatsink in place
      • The screws are held in place with retainer clips and are not fully removable
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 9300 Video Card Replacement: adım 9, 1 resimden 1.
      • Firmly pull up to unseat the video card from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Steven Faulkner
490 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Eyestone Fall 2016 USF Tampa, Team 16-6, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G6
5 Üyeler
22 adet Kılavuz yazıldı
1Rehber Yorum
This works only up to the point of pull up and away on the trackpad. The trackpad won't pull up.
cobrachoppergirl - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 1,254
