Giriş
Guide to replace or upgrade the video card in your Dell Inspiron 9300
Neye ihtiyacın var
Remove the battery prior to working on any internal components.
Remove the twelve 6mm Phillips screws from the bottom of the case.
Loosen the four 5mm Phillips screws holding the video card and heatsink in place
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
This works only up to the point of pull up and away on the trackpad. The trackpad won't pull up.
