Ana içeriğe geç
Dell Inspiron 9300 WIFI Card Replacement
Neye ihtiyacın var
  1. Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: adım 1, 3 resimden 1. Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: adım 1, 3 resimden 2. Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a size #0 Phillips screwdriver.
    • The screws do not come completely out.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
  2. Dell Inspiron 9300 WIFI Card Replacement: adım 2, 2 resimden 1. Dell Inspiron 9300 WIFI Card Replacement: adım 2, 2 resimden 2.
    • Once the screws are loose, open the panel using a plastic opening tool to access the components below.
    • The modem card should be labeled MODEM. The WIFI card is larger than the modem and closer to the outer edge of the computer.
  3. Dell Inspiron 9300 WIFI Card Replacement, WIFI Card: adım 3, 2 resimden 1. Dell Inspiron 9300 WIFI Card Replacement, WIFI Card: adım 3, 2 resimden 2.
    • Gently pry up on the gold antennae connections using a spudger.
    • Gently pry open both retaining clips on either side of the WiFi card using a spudger.
    • Once the clips are open and the card is unplugged, it is safe to remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Randy McMillan
738 İtibar
4 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.506 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 400
