Ana içeriğe geç
Dell Inspiron B130 CPU Replacement
Neye ihtiyacın var
  1. Dell Inspiron B130 CPU Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron B130 CPU Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron B130 CPU Replacement, Battery: adım 1, 3 resimden 3.
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 CPU Replacement: adım 2, 3 resimden 1. Dell Inspiron B130 CPU Replacement: adım 2, 3 resimden 2. Dell Inspiron B130 CPU Replacement: adım 2, 3 resimden 3.
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 CPU Replacement: adım 3, 3 resimden 1. Dell Inspiron B130 CPU Replacement: adım 3, 3 resimden 2. Dell Inspiron B130 CPU Replacement: adım 3, 3 resimden 3.
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 CPU Replacement, CPU: adım 4, 2 resimden 1. Dell Inspiron B130 CPU Replacement, CPU: adım 4, 2 resimden 2.
    • Remove the 6 mm screw.
    • Lift the plastic cover off.
  5. Dell Inspiron B130 CPU Replacement: adım 5, 2 resimden 1. Dell Inspiron B130 CPU Replacement: adım 5, 2 resimden 2.
    • Loosen the 4 screws.
    • These screws stay connected to the heat sink.
    • Remove the heat sink from the computer.
  6. Dell Inspiron B130 CPU Replacement: adım 6, 1 resimden 1.
    • Use a flat head screwdriver to turn the screw one quarter turn into the unlock position.
    • Remove the CPU.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Patrick McNeil
937 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-8, Catania Fall 2016 UMass Dartmouth, Team 1-8, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G8
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 353
