Ana içeriğe geç
Dell Inspiron B130 Fan Replacement
Neye ihtiyacın var
    1. Dell Inspiron B130 Fan Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron B130 Fan Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron B130 Fan Replacement, Battery: adım 1, 3 resimden 3.
      • First, make sure your computer is turned off.
      • Remove the battery by flipping the two switches under the battery and pulling it out
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron B130 Fan Replacement: adım 2, 3 resimden 1. Dell Inspiron B130 Fan Replacement: adım 2, 3 resimden 2. Dell Inspiron B130 Fan Replacement: adım 2, 3 resimden 3.
      • Push the tab from the battery, downwards to unlock the battery.
      • The tab should be in the position next to the unlocked indicator.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron B130 Fan Replacement: adım 3, 3 resimden 1. Dell Inspiron B130 Fan Replacement: adım 3, 3 resimden 2. Dell Inspiron B130 Fan Replacement: adım 3, 3 resimden 3.
      • Now, push the other tab (the one right under the battery) from right to left.
      • Now the battery will be loose; lift the battery up and out of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron B130 Fan Replacement, Disk Drive: adım 4, 3 resimden 1. Dell Inspiron B130 Fan Replacement, Disk Drive: adım 4, 3 resimden 2. Dell Inspiron B130 Fan Replacement, Disk Drive: adım 4, 3 resimden 3.
      • Remove the 8mm screw
      • Use the plastic opening tool to push out the disk drive.
      • Pull the disk drive out with the opposite hand.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron B130 Fan Replacement: adım 5, 1 resimden 1.
      • You can now remove the disk drive.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron B130 Fan Replacement, Hard Drive: adım 6, 3 resimden 1. Dell Inspiron B130 Fan Replacement, Hard Drive: adım 6, 3 resimden 2. Dell Inspiron B130 Fan Replacement, Hard Drive: adım 6, 3 resimden 3.
      • This particular computer is missing its hard drive.
      • Remove the two screws.
      • Remove the plastic cover by lifting from the groove as indicated.
      • Remove the hard drive from the computer by lifting up and out.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron B130 Fan Replacement, Keyboard: adım 7, 1 resimden 1.
      • Put down the computer and open up the screen.
      • There is a long piece of plastic underneath the screen that you will have to remove.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron B130 Fan Replacement: adım 8, 3 resimden 1. Dell Inspiron B130 Fan Replacement: adım 8, 3 resimden 2. Dell Inspiron B130 Fan Replacement: adım 8, 3 resimden 3.
      • When you pry the plastic plate off, be careful and pry gently so you do not crack the plastic.
      • Insert the plastic opening tool into the little slot.
      • Lift up gently and remove the plastic cover.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron B130 Fan Replacement: adım 9, 1 resimden 1.
      • Remove the two 4mm screws at the top of the keyboard.
      • The keyboard is now loose but don't pull it out just yet. It is still connected underneath. Be gentle when lifting keyboard so you do not damage this connection.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron B130 Fan Replacement: adım 10, 2 resimden 1. Dell Inspiron B130 Fan Replacement: adım 10, 2 resimden 2.
      • Lift keyboard up slightly and you will see the keyboard connection.
      • This black tab has to be lifted up to remove the keyboard.
      • Put your finger underneath the tab and pull back gently as indicated.
      • You can now remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron B130 Fan Replacement, Screen: adım 11, 2 resimden 1. Dell Inspiron B130 Fan Replacement, Screen: adım 11, 2 resimden 2.
      • Detach the blue display connector.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron B130 Fan Replacement: adım 12, 2 resimden 1. Dell Inspiron B130 Fan Replacement: adım 12, 2 resimden 2.
      • Detach the connector by pulling the two ends straight apart.
      • Avoid twisting or pulling at an angle to prevent damage.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron B130 Fan Replacement: adım 13, 1 resimden 1.
      • Use a Phillips #1 screwdriver to remove two 6 mm screws.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron B130 Fan Replacement: adım 14, 2 resimden 1. Dell Inspiron B130 Fan Replacement: adım 14, 2 resimden 2.
      • Close the computer and flip it over so that the back is facing up.
      • Remove the two 6mm screws that are behind each of the screen's pivot points using a Phillips #1 screwdriver.
      • Open up the screen and now it can be lifted up and off of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron B130 Fan Replacement, CPU: adım 15, 2 resimden 1. Dell Inspiron B130 Fan Replacement, CPU: adım 15, 2 resimden 2.
      • Remove the 6 mm screw.
      • Lift the plastic cover off.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron B130 Fan Replacement: adım 16, 2 resimden 1. Dell Inspiron B130 Fan Replacement: adım 16, 2 resimden 2.
      • Loosen the 4 screws.
      • These screws stay connected to the heat sink.
      • Remove the heat sink from the computer.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron B130 Fan Replacement: adım 17, 1 resimden 1.
      • Use a flat head screwdriver to turn the screw one quarter turn into the unlock position.
      • Remove the CPU.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron B130 Fan Replacement, RAM and Wireless: adım 18, 2 resimden 1. Dell Inspiron B130 Fan Replacement, RAM and Wireless: adım 18, 2 resimden 2.
      • Remove the three 6mm screws.
      • Lift the plastic cover off to reveal the RAM and the Wireless.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron B130 Fan Replacement: adım 19, 3 resimden 1. Dell Inspiron B130 Fan Replacement: adım 19, 3 resimden 2. Dell Inspiron B130 Fan Replacement: adım 19, 3 resimden 3.
      • To remove the RAM, push outward against the metal brackets.
      • The first RAM will pop up so you can just pull it right out.
      • Repeat the first step again to remove the second RAM chip.
      • Installation is the reverse of removal.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron B130 Fan Replacement: adım 20, 2 resimden 1. Dell Inspiron B130 Fan Replacement: adım 20, 2 resimden 2.
      • To remove the wireless chip, push outward on its two metal brackets.
      • Do not remove the chip just yet, the wire that connects this chip must first be removed.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron B130 Fan Replacement: adım 21, 2 resimden 1. Dell Inspiron B130 Fan Replacement: adım 21, 2 resimden 2.
      • To remove the wire, hold the wireless chip firmly and pull the connection straight up off of the chip.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron B130 Fan Replacement, Motherboard: adım 22, 2 resimden 1. Dell Inspiron B130 Fan Replacement, Motherboard: adım 22, 2 resimden 2.
      • Use a Phillips #0 screwdriver to remove the twelve 8mm screws from the bottom of the laptop.
      • The picture shows everything still installed in the computer. At this point, the CPU, RAM, battery, hard drive and wireless chip should all be removed.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron B130 Fan Replacement: adım 23, 2 resimden 1. Dell Inspiron B130 Fan Replacement: adım 23, 2 resimden 2.
      • Turn the laptop over so that the keyboard side is facing up.
      • Remove the two 4mm screws positioned just below where the screen would be using a Phillips #0 screwdriver.
      • Remove the five remaining 6mm screws.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron B130 Fan Replacement: adım 24, 2 resimden 1. Dell Inspiron B130 Fan Replacement: adım 24, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Disconnect the two connections carefully.
      • Do not pull by the wires! This can damage the connection. Use tweezers to grab by the white plastic piece and push outward.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron B130 Fan Replacement: adım 25, 3 resimden 1. Dell Inspiron B130 Fan Replacement: adım 25, 3 resimden 2. Dell Inspiron B130 Fan Replacement: adım 25, 3 resimden 3.
      • Disconnect this connection before proceeding.
      • Use tweezers to grab the small black connector and pull it straight back carefully. Avoid pulling on the wire directly, as this may cause damage to the connection.
      • You can now disconnect this wire.
      FixBot'a Sor
      Yorum Ekle
    5. Dell Inspiron B130 Fan Replacement: adım 26, 3 resimden 1. Dell Inspiron B130 Fan Replacement: adım 26, 3 resimden 2. Dell Inspiron B130 Fan Replacement: adım 26, 3 resimden 3.
      • Lift and remove the entire cover/frame from the top of the motherboard. Gently pull up to detach it without using excessive force
      • Remove the motherboard by pulling it upward and sliding it to the right. Be careful not to damage any remaining connectors or components. If the motherboard feels stuck, double-check that all screws and cables have been disconnected.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron B130 Fan Replacement, Fan: adım 27, 3 resimden 1. Dell Inspiron B130 Fan Replacement, Fan: adım 27, 3 resimden 2. Dell Inspiron B130 Fan Replacement, Fan: adım 27, 3 resimden 3.
      • Remove these four 4 mm screws.
      • Turn the motherboard over and lift the fan up.
      • Disconnect the wire that connects the fan to the motherboard by pulling up gently.
      • You can now remove the fan.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick McNeil
955 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-8, Catania Fall 2016 UMass Dartmouth, Team 1-8, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G8
3 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 602
