Ana içeriğe geç
Dell Inspiron B130 RAM and Wireless Replacement
Neye ihtiyacın var
  1. Dell Inspiron B130 RAM and Wireless Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron B130 RAM and Wireless Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron B130 RAM and Wireless Replacement, Battery: adım 1, 3 resimden 3.
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 RAM and Wireless Replacement: adım 2, 3 resimden 1. Dell Inspiron B130 RAM and Wireless Replacement: adım 2, 3 resimden 2. Dell Inspiron B130 RAM and Wireless Replacement: adım 2, 3 resimden 3.
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 RAM and Wireless Replacement: adım 3, 3 resimden 1. Dell Inspiron B130 RAM and Wireless Replacement: adım 3, 3 resimden 2. Dell Inspiron B130 RAM and Wireless Replacement: adım 3, 3 resimden 3.
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: adım 4, 2 resimden 1. Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: adım 4, 2 resimden 2.
    • Remove the three 6mm screws.
    • Lift the plastic cover off to reveal the RAM and the Wireless.
  5. Dell Inspiron B130 RAM and Wireless Replacement: adım 5, 3 resimden 1. Dell Inspiron B130 RAM and Wireless Replacement: adım 5, 3 resimden 2. Dell Inspiron B130 RAM and Wireless Replacement: adım 5, 3 resimden 3.
    • To remove the RAM, push outward against the metal brackets.
    • The first RAM will pop up so you can just pull it right out.
    • Repeat the first step again to remove the second RAM chip.
    • Installation is the reverse of removal.
  6. Dell Inspiron B130 RAM and Wireless Replacement: adım 6, 2 resimden 1. Dell Inspiron B130 RAM and Wireless Replacement: adım 6, 2 resimden 2.
    • To remove the wireless chip, push outward on its two metal brackets.
    • Do not remove the chip just yet, the wire that connects this chip must first be removed.
  7. Dell Inspiron B130 RAM and Wireless Replacement: adım 7, 2 resimden 1. Dell Inspiron B130 RAM and Wireless Replacement: adım 7, 2 resimden 2.
    • To remove the wire, hold the wireless chip firmly and pull the connection straight up off of the chip.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick McNeil
937 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-8, Catania Fall 2016 UMass Dartmouth, Team 1-8, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G8
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 263
