Ana içeriğe geç
Dell Inspiron Duo RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron Duo RAM Replacement, Front Cover: adım 1, 2 resimden 1. Dell Inspiron Duo RAM Replacement, Front Cover: adım 1, 2 resimden 2.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron Duo RAM Replacement: adım 2, 2 resimden 1. Dell Inspiron Duo RAM Replacement: adım 2, 2 resimden 2.
    • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
    • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron Duo RAM Replacement: adım 3, 2 resimden 1. Dell Inspiron Duo RAM Replacement: adım 3, 2 resimden 2.
    • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron Duo RAM Replacement, RAM: adım 4, 1 resimden 1.
    • With the cover removed, locate the 2GB RAM stick. It will be in the upper-middle portion of the device. The RAM stick is the flat blue rectangular object that has four black squares running along it vertically (for convenience, the RAM stick has been outlined in red in the photo).
    FixBot'a Sor
    Yorum Ekle
  5. Dell Inspiron Duo RAM Replacement: adım 5, 2 resimden 1. Dell Inspiron Duo RAM Replacement: adım 5, 2 resimden 2.
    • There are two white spring levers on either side of the RAM. Pull them out gently to release the RAM. This will cause the RAM to stick up at a forty-five degree angle.
    • With the RAM at a forty-five degree angle, gently pull it straight out of the device.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Inspiron Duo RAM Replacement: adım 6, 2 resimden 1. Dell Inspiron Duo RAM Replacement: adım 6, 2 resimden 2.
    • With the RAM stick flipped up, carefully lift it out of the slot.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Steven Luther
778 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-1, Liner SU 2015 UW Tacoma, Team 1-1, Liner SU 2015 üyesi
UWT-LINER-SU15S1G1
3 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Good effort, but incomplete. Laptop parts can be very easily damaged, so removing all the screws is important.
Chiel Kersten - Yanıt Paylaş
Good evening!!!
Is it possible to install a M.2 or NVME SSD in this netbook model?
Greetings and blessings from Venezuela!!!!
Edwin Guerra Avendaño - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 2,794
