Ana içeriğe geç
Dell Inspiron E1405 Heat Sink Replacement
Neye ihtiyacın var
  1. Dell Inspiron E1405 Heat Sink Replacement, Battery: adım 1, 1 resimden 1.
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 Heat Sink Replacement: adım 2, 3 resimden 1. Dell Inspiron E1405 Heat Sink Replacement: adım 2, 3 resimden 2. Dell Inspiron E1405 Heat Sink Replacement: adım 2, 3 resimden 3.
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: adım 3, 3 resimden 1. Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: adım 3, 3 resimden 2. Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: adım 3, 3 resimden 3.
    • Remove/loosen the eight 4.8mm screws with a #1 Phillips screwdriver securing the bottom panel.
    • Remove the bottom panel.
  4. Dell Inspiron E1405 Heat Sink Replacement: adım 4, 3 resimden 1. Dell Inspiron E1405 Heat Sink Replacement: adım 4, 3 resimden 2. Dell Inspiron E1405 Heat Sink Replacement: adım 4, 3 resimden 3.
    • Loosen the five 5.5mm screws with a #1 Phillips screwdriver securing the heat sink and clean it with compressed air
    • Gently lift the heat sink from the side, as indicated in the picture.
Sonuç
Sarah Neal Secrest
597 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G3, Bennett Spring 2017 Texas Tech, Team S8-G3, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 218
