Ana içeriğe geç
Dell Inspiron E1405 LCD Screen Replacement
Neye ihtiyacın var
  1. Dell Inspiron E1405 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 LCD Screen Replacement: adım 2, 3 resimden 1. Dell Inspiron E1405 LCD Screen Replacement: adım 2, 3 resimden 2. Dell Inspiron E1405 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: adım 3, 3 resimden 1. Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: adım 3, 3 resimden 2. Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: adım 3, 3 resimden 3.
    • Use your fingers or a spudger to remove the six small rubber covers off the display assembly.
    • Remove the six 5.7 mm screws with a Phillips #00 screwdriver.
  4. Dell Inspiron E1405 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Use your fingers to gently pry the front bezel off the display assembly. Start at a corner and work your way around.
    • Remove the front display bezel when it comes free.
  5. Dell Inspiron E1405 LCD Screen Replacement: adım 5, 3 resimden 1. Dell Inspiron E1405 LCD Screen Replacement: adım 5, 3 resimden 2. Dell Inspiron E1405 LCD Screen Replacement: adım 5, 3 resimden 3.
    • Remove the three 3.6 mm screws using a Phillips #00 screwdriver on both sides of the display.
    • Remove the LCD screen from the display assembly.
  6. Dell Inspiron E1405 LCD Screen Replacement: adım 6, 2 resimden 1. Dell Inspiron E1405 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Unplug the VGA cable by pushing the two metal sides towards the middle of the strip.
    • Gently pull the VGA cable away to release the strip.
  7. Dell Inspiron E1405 LCD Screen Replacement: adım 7, 2 resimden 1. Dell Inspiron E1405 LCD Screen Replacement: adım 7, 2 resimden 2.
    • Remove the next connection by pressing the two metal sides towards the middle. Then gently pull up the ribbon.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sarah Neal Secrest
597 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G3, Bennett Spring 2017 Texas Tech, Team S8-G3, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G3
3 Üyeler
Bir Yorum
I need complete body *Dell INSPIRON E1405 .
St Master Fun - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 437
