Ana içeriğe geç
Dell Inspiron E1405 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron E1405 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 RAM Replacement: adım 2, 3 resimden 1. Dell Inspiron E1405 RAM Replacement: adım 2, 3 resimden 2. Dell Inspiron E1405 RAM Replacement: adım 2, 3 resimden 3.
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 RAM Replacement, RAM: adım 3, 3 resimden 1. Dell Inspiron E1405 RAM Replacement, RAM: adım 3, 3 resimden 2. Dell Inspiron E1405 RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Locate the RAM access door.
    • Remove the two 5.5mm screws securing the RAM access door with a #00 Phillips screwdriver.
  4. Dell Inspiron E1405 RAM Replacement: adım 4, 1 resimden 1.
    • Using your fingers, open and remove the access door from the laptop, exposing the RAM underneath.
  5. Dell Inspiron E1405 RAM Replacement: adım 5, 3 resimden 1. Dell Inspiron E1405 RAM Replacement: adım 5, 3 resimden 2. Dell Inspiron E1405 RAM Replacement: adım 5, 3 resimden 3.
    • To access the RAM, push out the latches outward on the left and right of the RAM.
    • To remove the memory card, pull it out of the tray with the latches still stretched out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sarah Neal Secrest
597 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G3, Bennett Spring 2017 Texas Tech, Team S8-G3, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 565
