Neye ihtiyacın var
Before any work can be done ensure that the laptop is powered off.
Use either the power button on the computer or issue a shutdown from the operating system.
Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
On the back of the laptop there is a compartment for the RAM for easy access.
It is located right above the switch for the battery and has two phillips head screws as well as a sticker for the laptops product key.
Unscrew the two screws with a screwdriver and lift the backplate up to unveil the RAM.
2 farklı kişi bu kılavuzu tamamladı.
