Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn it upside down and locate the battery release switch.
While holding the switch in the open position, lift out the battery.
Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
Slide the hard drive tray out of the hard drive compartment.
Locate and remove the screw shown
It is labeled with a lock symbol
Use the screwdriver to gently push the optical drive out
Remove the 12 Phillips #1 screws from the edges of the lower case.
You may also need to remove the central screw next to the lock icon.
Turn the computer back over and tilt the screen open.
Use the plastic opening tool to carefully pry the panel out as shown in the pictures
Use the small Phillips head screwdriver to remove the screws circled in red.
Gently lift the keyboard up and rest it just below the screen as shown in the picture.
The keyboard will still be connected to the motherboard.
Before removing the keyboard completely, use the plastic opening tool to gently lift the clamp connecting the keyboard to the motherboard.
Once the keyboard has been disconnected, remove the keyboard completely.
Using a Phillips head screwdriver, remove the screws shown in the image. They all have the letter "P" next to them.
Carefully unplug the connections shown.
Also, the wireless cables on the right side may prevent moving the upper case out of the way.
Once the screws have been removed and the connections unplugged, use the plastic opening tool to gently separate the panel from the lower case.
Remove the plastic case by gently bending back towards the screen. You can bend the screen all the way back if that helps.
Remove the 4 screws indicated in the first picture
Gently lift up the videocard and heat sync from the motherboard.
Remove both fans from the computer. This will make it easier to remove the motherboard.
Remove the screws in the photos to remove the fans.
Unplug the shown leads by gently pulling them up.
Remove the shown screws from the motherboard
Gently remove the motherboard from the laptop by simultaneously lifting and pulling away from the sides.
Once the motherboard is free, flip it over, towards the screen of the laptop and gently remove the black and white wire from the wireless card.
Once the wires are disconnected, pull them through the hole and completely remove the motherboard from the computer.
Your computer should look like the computer in the photo without the motherboard.
5 farklı kişi bu kılavuzu tamamladı.
