Ana içeriğe geç
Dell Inspiron E1705 Optical Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron E1705 Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Optical Drive Replacement: adım 2, 2 resimden 1. Dell Inspiron E1705 Optical Drive Replacement: adım 2, 2 resimden 2.
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 Optical Drive Replacement, Optical Drive: adım 3, 1 resimden 1.
    • Locate and remove the screw shown
    • It is labeled with a lock symbol
  4. Dell Inspiron E1705 Optical Drive Replacement: adım 4, 2 resimden 1. Dell Inspiron E1705 Optical Drive Replacement: adım 4, 2 resimden 2.
    • Use the screwdriver to gently push the optical drive out
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Evan Fairchild
613 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-5, Maness Fall 2010 Cal Poly, Team 22-5, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G5
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 3,958
