Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn it upside down and locate the battery release switch.
While holding the switch in the open position, lift out the battery.
Turn the computer over, screen closed, so that the underside is showing
Locate the two screws as shown and remove them.
Use a small phillips head screwdriver
Remove plastic cover carefully
There will be two RAM sticks as shown
Using your fingers, pull the sides apart that are holding the RAM in place. This will release the RAM.
Carefully remove old/damaged RAM sticks and replace with new ones.
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
If upgrading RAM, a black DOS based screen will show stating "the amount of RAM in system has changed", wait 1minute and the computer will beep and prompt for F1 (boot normally) or F2 (run system setup utility). Pressing F2 and waiting some time will allow the computer to reconfigure and then boot into Windows normally.
