Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
There is some disassembly required. You will want to prepare a clean and organized work space for this repair.
Parçalar
Hiçbir parça belirtilmedi.
  1. Use a spudger or your fingernail to pry out the 6 rubber and 2 plastic pieces on the bezel of the display.
    • Use a spudger or your fingernail to pry out the 6 rubber and 2 plastic pieces on the bezel of the display.
    • Use a small phillips head screwdriver to remove the 8 screws.
  2. Use a plastic opening tool to carefully pry the plastic cover from the screen mount. Use a plastic opening tool to carefully pry the plastic cover from the screen mount.
    • Use a plastic opening tool to carefully pry the plastic cover from the screen mount.
  3. Remove the 4 screws along EACH side of the screen. 8 screws total
    • Remove the 4 screws along EACH side of the screen.
    • 8 screws total
    • Now use the spudger to lift the screen and rotate away from you.
  4. Lift the screen up and out using the spudger tool Tilt the screen away from you
    • Lift the screen up and out using the spudger tool
    • Tilt the screen away from you
    • The screen will be connected by two leads. See picture
  5. Locate the two leads and gently remove them from the screen. They will stay connected to the computer. Do not touch the taped, white backing on your replacement monitor.
    • Locate the two leads and gently remove them from the screen. They will stay connected to the computer.
    • Do not touch the taped, white backing on your replacement monitor.
    • Remove the screen carefully.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Evan Fairchild
598 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 22-5, Maness Fall 2010 Cal Poly, Team 22-5, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G5
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 6,749
