Ana içeriğe geç
Dell Inspiron M5010 Palm Rest Replacement
Neye ihtiyacın var
  1. Dell Inspiron M5010 Palm Rest Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron M5010 Palm Rest Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 Palm Rest Replacement, Remove keyboard retaining screw: adım 2, 1 resimden 1.
    • Remove Keyboard retaining screw from bottom of laptop.
  3. Dell Inspiron M5010 Palm Rest Replacement: adım 3, 3 resimden 1. Dell Inspiron M5010 Palm Rest Replacement: adım 3, 3 resimden 2. Dell Inspiron M5010 Palm Rest Replacement: adım 3, 3 resimden 3.
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  4. Dell Inspiron M5010 Palm Rest Replacement: adım 4, 1 resimden 1.
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  5. Dell Inspiron M5010 Palm Rest Replacement: adım 5, 1 resimden 1.
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
  6. Dell Inspiron M5010 Palm Rest Replacement, Palm Rest: adım 6, 1 resimden 1.
    • Flip the laptop, so the bottom of the laptop is facing up.
    • Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
  7. Dell Inspiron M5010 Palm Rest Replacement: adım 7, 2 resimden 1. Dell Inspiron M5010 Palm Rest Replacement: adım 7, 2 resimden 2.
    • Flip the laptop back over, so that the top of the laptop is facing up.
    • Open the laptop.
    • Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
  8. Dell Inspiron M5010 Palm Rest Replacement: adım 8, 1 resimden 1.
    • Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
  9. Dell Inspiron M5010 Palm Rest Replacement: adım 9, 3 resimden 1. Dell Inspiron M5010 Palm Rest Replacement: adım 9, 3 resimden 2. Dell Inspiron M5010 Palm Rest Replacement: adım 9, 3 resimden 3.
    • Carefully unsnap and remove the palm rest.
    • Place your fingers inside the large circle in the lower right corner to get a good grip.
Sonuç
April Poucher
1.164 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-5, Benson Fall 2014 Clemson, Team 1-5, Benson Fall 2014 üyesi
CLEM-BENSON-F14S1G5
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 524
