Ana içeriğe geç
Dell Inspiron M5030 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron M5030 Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Dell Inspiron M5030 Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop.
    • Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
    If you are removing only the keyboard, you only need to remove two screws.
    1 - Remove the screw to the immediate right of the INSPIRON M5030 label.
    2 - To the top left of the INSPIRON M5030 label, there are two screws. Remove the left one.
    I marked the two screw locations with green, for clarification.
    - https://ibb.co/nz4rNG
    - https://postimg.org/image/67kinagal/
    Robert Johnson - Yanıt
  2. Dell Inspiron M5030 Keyboard Replacement: adım 2, 2 resimden 1. Dell Inspiron M5030 Keyboard Replacement: adım 2, 2 resimden 2.
    • Turn the laptop over and open the lid.
    • Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
    • With one of your hands, push the leftmost tab down with the plastic opening tool (above the F1 key). With your other hand, lift the left side of the keyboard.
    • Push the middle tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the F6 key).
    • Push the rightmost tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the PrntScr key). The keyboard should be loosened from the laptop after these steps.
    for your last bullet, maybe clarify saying "push the next to tabs with the plastic opening tool…"
    Katie Pepi - Yanıt
  3. Dell Inspiron M5030 Keyboard Replacement: adım 3, 2 resimden 1. Dell Inspiron M5030 Keyboard Replacement: adım 3, 2 resimden 2.
    • After the top edge of the keyboard is loose, pull up on the keyboard gently.
    • Do not pull the keyboard up forcefully as the keyboard is still attached to the laptop by a ribbon.
  4. Dell Inspiron M5030 Keyboard Replacement: adım 4, 3 resimden 1. Dell Inspiron M5030 Keyboard Replacement: adım 4, 3 resimden 2. Dell Inspiron M5030 Keyboard Replacement: adım 4, 3 resimden 3.
    • Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard.
    • Locate the blue end of the ribbon which is connected to the motherboard.
    • Lift up the black flap on the connector and gently pull the ribbon away from the connector which is parallel to the motherboard.
    • Lift the keyboard up and off of the motherboard. Detach the blue end of the ribbon from the connector.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ryan Moelter
382 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-44, Maness Spring 2014 Cal Poly, Team 3-44, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G44
4 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
Do you know any ways to replace 4 keys Spacebar,B,N and the Slash/Question Mark are broken plz help
Snapchat Hotdog - Yanıt
The keyboard is best handled as a whole part replacement. You can find M5030 replacement keyboards for about $10 on Amazon/eBay.
Robert Johnson -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,328
