Ana içeriğe geç
Dell Inspiron M5110 Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron M5110 Display Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Display Assembly Replacement: adım 2, 1 resimden 1.
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Display Assembly Replacement: adım 3, 1 resimden 1.
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Display Assembly Replacement, Keyboard: adım 4, 1 resimden 1.
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Display Assembly Replacement: adım 5, 1 resimden 1.
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Display Assembly Replacement: adım 6, 1 resimden 1.
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Display Assembly Replacement: adım 7, 1 resimden 1.
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Display Assembly Replacement: adım 8, 1 resimden 1.
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Display Assembly Replacement: adım 9, 1 resimden 1.
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
  10. Dell Inspiron M5110 Display Assembly Replacement, Palmrest: adım 10, 1 resimden 1.
    • Turn the computer over and remove the six screws that secure the palmrest assembly
  11. Dell Inspiron M5110 Display Assembly Replacement: adım 11, 1 resimden 1.
    • Turn the computer over and open the display as far as possible and remove the four 5 mm Phillips # 0 screw holding the palmrest in place.
  12. Dell Inspiron M5110 Display Assembly Replacement: adım 12, 2 resimden 1. Dell Inspiron M5110 Display Assembly Replacement: adım 12, 2 resimden 2.
    • Disconnect the power button board cable, touch pad cable and the hot key board cable from the connectors.
  13. Dell Inspiron M5110 Display Assembly Replacement: adım 13, 2 resimden 1. Dell Inspiron M5110 Display Assembly Replacement: adım 13, 2 resimden 2.
    • Use a plastic opening tool to carefully pry out the palmrest assembly and lift it off the computer base.
  14. Dell Inspiron M5110 Display Assembly Replacement, Display Assembly: adım 14, 1 resimden 1.
    • Turn the device over and then remove the two 5 mm Phillips #0 screws that keeps the display assembly to the base and then flip the device.
  15. Dell Inspiron M5110 Display Assembly Replacement: adım 15, 1 resimden 1.
    • Disconnect the display antenna cable from the Mini Card.
  16. Dell Inspiron M5110 Display Assembly Replacement: adım 16, 1 resimden 1.
    • Disconnect the LCD display cable and touch screen cable.
  17. Dell Inspiron M5110 Display Assembly Replacement: adım 17, 2 resimden 1. Dell Inspiron M5110 Display Assembly Replacement: adım 17, 2 resimden 2.
    • There are two 5 mm Phillips # 0 screws on each hinge.
    • Unscrew the four 5 mm Phillips # 0 screws holding the hinge that keeps the monitor in place.
  18. Dell Inspiron M5110 Display Assembly Replacement: adım 18, 1 resimden 1.
    • Lift the display off the computer base.
Sonuç
Maxwell Dumerant
19 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Catania Fall 2016 UMass Dartmouth, Team 4-3, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 252
