Ana içeriğe geç
Dell Inspiron M5110 Optical Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron M5110 Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Optical Drive Replacement: adım 2, 1 resimden 1.
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Optical Drive Replacement: adım 3, 1 resimden 1.
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Optical Drive Replacement, Module Cover: adım 4, 2 resimden 1. Dell Inspiron M5110 Optical Drive Replacement, Module Cover: adım 4, 2 resimden 2.
    • Remove the 5 mm Phillips # 0 screw in the middle of the device.
  5. Dell Inspiron M5110 Optical Drive Replacement: adım 5, 1 resimden 1.
    • Remove the module cover pressing in the release tabs and pulling the cover up and away from the base of the device.
  6. Dell Inspiron M5110 Optical Drive Replacement, Optical Drive: adım 6, 2 resimden 1. Dell Inspiron M5110 Optical Drive Replacement, Optical Drive: adım 6, 2 resimden 2.
    • Insert a small screwdriver into the hole and slide the optical drive away from the center of the device. This will slide the optical assembly out from the side of the device.
  7. Dell Inspiron M5110 Optical Drive Replacement: adım 7, 1 resimden 1.
    • Slide the optical drive assembly the rest of the way out of the device.
Sonuç
Cody Flynn
331 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Catania Fall 2016 UMass Dartmouth, Team 4-3, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 216
