Ana içeriğe geç
Dell Inspiron M531R-5535 Fan Replacement
Neye ihtiyacın var
  1. Dell Inspiron M531R-5535 Fan Replacement, Fan: adım 1, 3 resimden 1. Dell Inspiron M531R-5535 Fan Replacement, Fan: adım 1, 3 resimden 2. Dell Inspiron M531R-5535 Fan Replacement, Fan: adım 1, 3 resimden 3.
    • Flip the laptop over and unlock the battery.
    • Lift up to remove the battery.
  2. Dell Inspiron M531R-5535 Fan Replacement: adım 2, 2 resimden 1. Dell Inspiron M531R-5535 Fan Replacement: adım 2, 2 resimden 2.
    • Loosen the two Phillips #1 screws to remove the tray.
    • The screws stay in the tray.
  3. Dell Inspiron M531R-5535 Fan Replacement: adım 3, 2 resimden 1. Dell Inspiron M531R-5535 Fan Replacement: adım 3, 2 resimden 2.
    • Unscrew the 3.6mm Phillips #1 screw.
    • Slide the CD Drive out.
  4. Dell Inspiron M531R-5535 Fan Replacement: adım 4, 2 resimden 1. Dell Inspiron M531R-5535 Fan Replacement: adım 4, 2 resimden 2.
    • Unscrew nine 5.7mm Phillips #1 screws.
    • Unscrew three 5.6mm Phillips #1 screws
    • The three 5.6mm Phillips #1 screws are thinner.
    • Then flip the laptop and open it to see the keyboard.
  5. Dell Inspiron M531R-5535 Fan Replacement: adım 5, 2 resimden 1. Dell Inspiron M531R-5535 Fan Replacement: adım 5, 2 resimden 2.
    • Use a nylon spudger or plastic opening tool to press into the highlighted keyboard latches.
  6. Dell Inspiron M531R-5535 Fan Replacement: adım 6, 3 resimden 1. Dell Inspiron M531R-5535 Fan Replacement: adım 6, 3 resimden 2. Dell Inspiron M531R-5535 Fan Replacement: adım 6, 3 resimden 3.
    • Lift up the keyboard.
    • Lift up on the black ZIF tab and pull the keyboard ribbon cable free.
  7. Dell Inspiron M531R-5535 Fan Replacement: adım 7, 2 resimden 1. Dell Inspiron M531R-5535 Fan Replacement: adım 7, 2 resimden 2.
    • Unscrew the five 5.6mm Phillips #1 screws.
    • Unscrew the two 3.6mm Phillips #1 screws.
  8. Dell Inspiron M531R-5535 Fan Replacement: adım 8, 2 resimden 1. Dell Inspiron M531R-5535 Fan Replacement: adım 8, 2 resimden 2.
    • Disconnect all highlighted cables.
  9. Dell Inspiron M531R-5535 Fan Replacement: adım 9, 2 resimden 1. Dell Inspiron M531R-5535 Fan Replacement: adım 9, 2 resimden 2.
    • Using an opening tool, carefully pry open the case from the side.
  10. Dell Inspiron M531R-5535 Fan Replacement: adım 10, 1 resimden 1.
    • Unscrew the Phillips #1 screw.
    • Pull the white connector out to disconnect the cables from the motherboard.
    • Pull up on gold connectors (MHF4) to disconnect the cables connecting the WLAN card.
    • Pull up on the white flap and pull out the strip to disconnect the strip from the motherboard.
  11. Dell Inspiron M531R-5535 Fan Replacement: adım 11, 1 resimden 1.
    • Flip the motherboard over.
    • Pull the white connector out to disconnect the fan.
    • Lift the fan to remove it from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tony Chen
310 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 6-5, Adachi Fall 2022 CSU Los Angeles, Team 6-5, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S6G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 226
