Ana içeriğe geç
Dell Inspiron Mini 10 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron Mini 10 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  4. Dell Inspiron Mini 10 Keyboard Replacement: adım 4, 1 resimden 1.
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  5. Dell Inspiron Mini 10 Keyboard Replacement: adım 5, 2 resimden 1. Dell Inspiron Mini 10 Keyboard Replacement: adım 5, 2 resimden 2.
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  6. Dell Inspiron Mini 10 Keyboard Replacement: adım 6, 2 resimden 1. Dell Inspiron Mini 10 Keyboard Replacement: adım 6, 2 resimden 2.
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
Sonuç
Danielle Jarecki
334 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016 üyesi
UWT-ROSE-F16S1G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 1,333
