Ana içeriğe geç
Dell Inspiron Mini 1012: Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron Mini 1012: Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the battery
  2. Dell Inspiron Mini 1012: Keyboard Replacement: adım 2, 1 resimden 1.
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Dell Inspiron Mini 1012: Keyboard Replacement: adım 3, 2 resimden 1. Dell Inspiron Mini 1012: Keyboard Replacement: adım 3, 2 resimden 2.
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  4. Dell Inspiron Mini 1012: Keyboard Replacement: adım 4, 1 resimden 1.
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Marie K Bordley
241 İtibar
2 adet Kılavuz yazıldı
Ekip
Ohio State, Team 1-1, Buehl Fall 2014 Ohio State, Team 1-1, Buehl Fall 2014 üyesi
OSU-BUEHL-F14S1G1
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
After keyboard open, You can change HDD or Memory as you like.
최희욱 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 11
Her zaman: 3,268
