1. Remove the battery
    • Remove the battery
  2. Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  5. Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Marie K Bordley
226 İtibar
2 adet Kılavuz yazıldı
Takım
Ohio State, Team 1-1, Buehl Fall 2014 Ohio State, Team 1-1, Buehl Fall 2014 üyesi
OSU-BUEHL-F14S1G1
4 Üyeler
Bir Yorum
After keyboard open, You can change HDD or Memory as you like.
최희욱 - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 20
Her zaman: 2,702
