Ana içeriğe geç
Dell Inspiron Mini 1012 Battery Replacement
  1. Dell Inspiron Mini 1012 Battery Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron Mini 1012 Battery Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron Mini 1012 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Turn the device over so the bottom is facing upwards.
    • Slide the two tabs beside the lock icons to the unlocked position.
    • Find the notch located in the center between the two tabs and lift up on the battery to remove it.
    • To replace the battery, align the three notches on the battery with the grooves on the device. Snap the battery back onto the device, and it will lock in place.
Sonuç
To reassemble, place the new battery in the three slots. Lock the battery back in place.
sabinabarajas
372 İtibar
3 adet Kılavuz yazıldı
Ekip
Gateway, Team 2-2, Kuhn Fall 2015 Gateway, Team 2-2, Kuhn Fall 2015 üyesi
GCC-KUHN-F15S2G2
1 Üye
6 adet Kılavuz yazıldı
Bir Yorum
So, I’ve installed the new battery and the mini 1012 won’t recognize or charge it. Now what?
complainingparty - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 1,476
