Ana içeriğe geç
Dell Inspiron Mini 1012 Screen Replacement
Neye ihtiyacın var
  1. Dell Inspiron Mini 1012 Screen Replacement, Screen: adım 1, 3 resimden 1. Dell Inspiron Mini 1012 Screen Replacement, Screen: adım 1, 3 resimden 2. Dell Inspiron Mini 1012 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Remove the battery from the device for safety. Slide the two tabs on the bottom of the computer to the unlocked position, and gently lift up the battery.
    • Remove the two rubber pieces at the bottom of the screen and remove the screws located behind them.
    • Carefully remove the plastic casing from the device.
  2. Dell Inspiron Mini 1012 Screen Replacement: adım 2, 3 resimden 1. Dell Inspiron Mini 1012 Screen Replacement: adım 2, 3 resimden 2. Dell Inspiron Mini 1012 Screen Replacement: adım 2, 3 resimden 3.
    • Remove the four screws on each corner of the screen. Then remove the screws located on the side of the screen.
    • Carefully unplug the ribbon on the back of the screen.
  3. Dell Inspiron Mini 1012 Screen Replacement: adım 3, 3 resimden 1. Dell Inspiron Mini 1012 Screen Replacement: adım 3, 3 resimden 2. Dell Inspiron Mini 1012 Screen Replacement: adım 3, 3 resimden 3.
    • Place the new screen onto the device and plug the ribbon in.
    • Replace the screws on the side of the screen.
  4. Dell Inspiron Mini 1012 Screen Replacement: adım 4, 3 resimden 1. Dell Inspiron Mini 1012 Screen Replacement: adım 4, 3 resimden 2. Dell Inspiron Mini 1012 Screen Replacement: adım 4, 3 resimden 3.
    • Snap on the plastic screen cover and replace the two screws and the rubber pieces at the bottom of the screen.
    • Turn the computer over and put the battery back in.
Sonuç
To reassemble your device, follow guide instructions.
2 farklı kişi bu kılavuzu tamamladı.
sabinabarajas
372 İtibar
3 adet Kılavuz yazıldı
Ekip
Gateway, Team 2-2, Kuhn Fall 2015 Gateway, Team 2-2, Kuhn Fall 2015 üyesi
GCC-KUHN-F15S2G2
1 Üye
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,323
