Ana içeriğe geç
Dell Inspiron N4010 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron N4010 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Keyboard Replacement: adım 2, 2 resimden 1. Dell Inspiron N4010 Keyboard Replacement: adım 2, 2 resimden 2.
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Keyboard Replacement: adım 3, 1 resimden 1.
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Dell Inspiron N4010 Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Dell Inspiron N4010 Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Keyboard Replacement: adım 5, 1 resimden 1.
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Keyboard Replacement: adım 7, 2 resimden 1. Dell Inspiron N4010 Keyboard Replacement: adım 7, 2 resimden 2.
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Keyboard Replacement: adım 8, 2 resimden 1. Dell Inspiron N4010 Keyboard Replacement: adım 8, 2 resimden 2.
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Keyboard Replacement: adım 9, 2 resimden 1. Dell Inspiron N4010 Keyboard Replacement: adım 9, 2 resimden 2.
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jonathan Sellier
952 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G5, Boczar Fall 2017 USF Tampa, Team S13-G5, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S13G5
5 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 1,096
