Ana içeriğe geç
Dell Inspiron N4110 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron N4110 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 RAM Replacement: adım 2, 1 resimden 1.
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 RAM Replacement: adım 3, 1 resimden 1.
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 RAM Replacement, RAM: adım 4, 2 resimden 1. Dell Inspiron N4110 RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Locate and unscrew the one 2.5x5 mm screw on the cover.
    • The screw does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
  5. Dell Inspiron N4110 RAM Replacement: adım 5, 2 resimden 1. Dell Inspiron N4110 RAM Replacement: adım 5, 2 resimden 2.
    • Remove RAM cover from the laptop.
  6. Dell Inspiron N4110 RAM Replacement: adım 6, 2 resimden 1. Dell Inspiron N4110 RAM Replacement: adım 6, 2 resimden 2.
    • Use your fingers to separate the two metal clips from the RAM.
    • The RAM will lift up when properly separated. Do not force the RAM out of the clips.
  7. Dell Inspiron N4110 RAM Replacement: adım 7, 1 resimden 1.
    • Remove the RAM from the computer.
    • Be careful as to not touch the metal on the bottom of the RAM. This can cause damage.
    • The RAM should be placed on a non-conductive surface.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Olivia
773 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G1, Peak Spring 2018 UMass Dartmouth, Team S5-G1, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 770
