Ana içeriğe geç
Dell Inspiron N4110 Screen Replacement
Neye ihtiyacın var
  1. Dell Inspiron N4110 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Screen Replacement: adım 2, 1 resimden 1.
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Screen Replacement: adım 3, 1 resimden 1.
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Screen Replacement, Screen: adım 4, 3 resimden 1. Dell Inspiron N4110 Screen Replacement, Screen: adım 4, 3 resimden 2. Dell Inspiron N4110 Screen Replacement, Screen: adım 4, 3 resimden 3.
    • Use your hands to remove the plastic cover from around the screen.
    • This can seem difficult, but it can be done.
  5. Dell Inspiron N4110 Screen Replacement: adım 5, 2 resimden 1. Dell Inspiron N4110 Screen Replacement: adım 5, 2 resimden 2.
    • Unscrew the two 2.5x4 mm screws from the top of the screen.
  6. Dell Inspiron N4110 Screen Replacement: adım 6, 2 resimden 1. Dell Inspiron N4110 Screen Replacement: adım 6, 2 resimden 2.
    • Loosen the four 2.5x4 mm screws from the base of the screen.
    • This will allow the screen to lift from inside the top of the case.
  7. Dell Inspiron N4110 Screen Replacement: adım 7, 3 resimden 1. Dell Inspiron N4110 Screen Replacement: adım 7, 3 resimden 2. Dell Inspiron N4110 Screen Replacement: adım 7, 3 resimden 3.
    • Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
  8. Dell Inspiron N4110 Screen Replacement: adım 8, 2 resimden 1. Dell Inspiron N4110 Screen Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to peel the webcam away from the top of the laptop.
    • The webcam is only held in place by a webcam, this is easy to pull away from the screen.
  9. Dell Inspiron N4110 Screen Replacement: adım 9, 3 resimden 1. Dell Inspiron N4110 Screen Replacement: adım 9, 3 resimden 2. Dell Inspiron N4110 Screen Replacement: adım 9, 3 resimden 3.
    • Lift the adhesive flap from the cord that connects the computer to the screen.
    • You can then disconnect the cord from the screen.
  10. Dell Inspiron N4110 Screen Replacement: adım 10, 1 resimden 1.
    • The screen can now be fully removed from the computer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Abigail Keith
505 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G1, Peak Spring 2018 UMass Dartmouth, Team S5-G1, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 1,229
